Hello, does anybody have information - can the MKS TFT32 touchscreen - from the “previous version” RS-CNC - be used with GRBL?
I ordered several MakerFr CNC shields and MKS TFT32 touchscreens back in November 2018.
Now I finally got around to using the set, but I found that Marlin seems to be too limiting for more serious CNC work.
If anyone has any further information to point me in the right direction, I would be very grateful.
Best regards,
Marti
Using MKS TFT32 touchscreen with GRBL?
Re: Using MKS TFT32 touchscreen with GRBL?
Hi Martis,
GRBL doesn't work with the previous shield, it's because we made the new GRBL32bits board.
Have a good day
Romain
Have a good day
Romain
Thank you Romain!
I'm a big fan of screw connections for wires, so I'm using a separate screw shield on my Arduino Mega anyway (see link: https://www.aliexpress.com/item/3280972 ... 4c4dGejF2G)
So, if there are GRBL pinouts missing on the "old" MakerFr shield - that will not be a problem for me, I can get all the pins that GRBL is using from my screw connections.
What I am rather interested in - can MKS TFT32 touchscreen be made to work together with GRBL running on Arduino Mega?
Has anyone tried it or seen in some forums?
I found that MKS has a GRBL firmware for smaller TFT28 touchscreen but I doubt it would directly work on the TFT32 screen.
Marti
Marti
It's not a connection problem with GRBL, but a chip problem. GRBL doesn't work with mega2560 boards !
And the MKS TFT32 firmware is made to work with Marlin/repetier/smoothieware and not GRBL wich is using different g-code commands, MKS TFTs are closed source and we can not modify the firmware except the config file
