Furthermore:
When I turn on the RS-CNC and try to use the Nunchucks it does not move in the correct directions - have to do a reset, before it behaves!
When I have used the Nunchuck to move the CNC I sometimes cannot move it with the TFT
Software solution etc.
Re: Software solution etc.
Hi Drelig,
Have you tested with another Nunchuck ? Or verify that you don't have a wrong contact on the plug ?
We can not move the axis by TFT after moving by Nunchuck, it's a known bug, and we don't understand why for the moment, we are finding a solution, it's because firmware is still in beta version.
Hi Romaker
Have You read my previous post about the new TFT (23.October 15.30)?
No problem with the contact on the Nunchuck. I will see if I can get hold of an original Nunchuck and see if that will work.
Thanks from Dregild
Thanks from Dregild
Now, I’m up an running I’m having very similar problems. The axis all work but the control from the Nunchuk is rather random, and often in one direction. Once I have tried the Nunchuk the TFT doesn’t allow any movements.
Is it best to wait until you’ve had chance to look at the firmware or is it worth loading a previous version as I can see for some people that seem to work.
Many thanks
Many thanks
