Electronics problem.
kane77
Re: Electronics problem.
Message par kane77 »
I reinstalled the original firmware before I tested the other nunchucks.im not getting 1v on the nunchuck pcb would this be a problem with the arduino or the sheild pcb?
The 3.3v needed is powered by the mega2560 board.
Remove the shield, power the arduino (with12v max) check the tension between 3.3v output hole and gnd on the arduino.
i just checked, i got 3.3v on arduino 3.3v output and 3.3v on nunchuk plug, you should have the same
kane77
All sorted.i had a faulty arduino mega board.once I swapped it out all my problems went away :D
Kachidoki
Message par Kachidoki »
Glad you fixed up your issue. ;)
kane77
Thanks for all your help and thanks for designing this awesome machine.now I have to go and learn how to use it
Yes ! Happy to hear that :D
