Question RS-CNC
19Ted54
Question RS-CNC
Message par 19Ted54 »
Hello Romain!
You say in the improvements list for the RS-CNC that there is room for machine enlargements -
# Would a machinable surface of X = 550mm \ Y = 1100mm \ Z = 75mm be possible and what should I keep in mind when enlarging the 'Y' of the machine?
# The software would cope with it, or?
Thanks a lot for your answer, maybe I should translate this with 'Google Translate' and put it in the French section of the forum?
Kind regards, Eduard
Viribus Unitis
Re: Question RS-CNC
Hi Eduards,
Yes you can enlarge the machine, you don't need modify the firmware !
You can speak in English, my English is not perfect but i understand everything you write ;)
