Hi all i am in the middle of connecting all the cable but i cannot see in the instructions where to connect the 2 12v fans i am using do i merely connect it to the 12v supply?
Aze a écrit :Yes, direct to the power supply if it's a 12v.
Thanks Aze
Yes the power supply is 24v but i have the 12v converter for the led so i will connect them to the smae as the led just didnt know if i could add it to the board somewhere.
It's easier to plug it on the 12v converter, otherwise you can meld 2 pins on the ramps near the green power entry and plug your fan here.
(extruderfan on the picture): http://i.imgur.com/KOjq6ri.jpg
