hi guys I wanted to discuss with you on the subject of the post.
Let's start with the milling speed I set it at 900 mm / min for all processes. it is a little low and the work takes a little longer but the machine works well. How much do you set it?
Tool penetration thickness, I use 3mm for roughing with the classic 6mm cutter for roughing. This is also not much and affects time, how much do you set this parameter?
Finally, the types of cutters. I bought a lot of various types on aliexpress, they are cheap even if they are of fair quality, where do you buy them?
Hi.
